Salta al contenuto principale
Atari Flashback 2 Console Power Button Replacement
Faith Julian
Faith Julian e 4 altri collaboratori
Ultimo aggiornamento il 21 lug 2021
30 minuti
Moderato
Introduzione
Vai al passo 1
If the button on an Atari Flashback 2 console is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the console in order to access the buttons to do so.
Cosa ti serve
Strumenti
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, immagine 1 di 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, immagine 2 di 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, immagine 3 di 3
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Console Power Button Replacement: passo 2, immagine 1 di 3 Atari Flashback 2 Console Power Button Replacement: passo 2, immagine 2 di 3 Atari Flashback 2 Console Power Button Replacement: passo 2, immagine 3 di 3
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
Conclusione
Faith Julian
Membro da: 09/18/18
205 Reputazione
2 Guide realizzate
1Commento della guida
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 27
Tutti i Tempi: 968
