Salta al contenuto principale
Apple Cinema Display M8149 LCD Screen Replacement
Curtis Musashi
Curtis Musashi e 11 altri collaboratori
Ultimo aggiornamento il 21 dic 2022
45 minuti - 1 ora
Moderato
Foto Azione
Passi mancanti
Introduzione
Vai al passo 1
If the display on your Apple Cinema Display M8149 isn’t turning on, is pixelated, or is cracked, use this guide to replace the LCD screen.
The LCD (liquid crystal display) screen is for displaying computer-generated images. Liquid crystals use a backlight or reflector to produce images in color or monochrome. An LCD screen with a faulty backlight or reflector can cause a display to not work properly.
Before using this guide, if the display is cracked or shattered, clean up shards of glass before and during replacement. Additionally, make sure to unplug the display to prevent damage.
In this guide, you will be removing the back cover and two different circuit boards before removing the LCD screen.
After performing the screen replacement, the screen will turn on to display images.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: passo 1, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: passo 1, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: passo 1, immagine 3 di 3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
    Mine had hex head screws instead of Phillips head.
    Bill Greene - Replica
    Hex 2.0 screws here too!
    dietrichbatista - Replica
  2. Apple Cinema Display M8149 LCD Screen Replacement: passo 2, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 2, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
    AND: Shall we mention right here, there is a small white connector leading to the display's POWER button that should be disconnected to slide the back plate off.
    spudmcat - Replica
    These screws too were hex head, not PH2, on my display.
    Exactly: Hex 2.0 screws
  3. Apple Cinema Display M8149 LCD Screen Replacement: passo 3, immagine 1 di 2 Apple Cinema Display M8149 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
    Here and on the next step you’ll m
    need a PH 2 screwdriver
  4. Apple Cinema Display M8149 LCD Screen Replacement: passo 4, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 4, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
    There are 2 Phillips screws at the center top and center bottom that need to be removed as well. They are parallel to the work surface if the screen is flat. The control board must be lifted slightly to access the screws. There's also a clip holding the disconnected power connector to the mechanisms below.
    About This Matt - Replica
  5. Apple Cinema Display M8149 LCD Screen Replacement: passo 5, immagine 1 di 2 Apple Cinema Display M8149 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Gently lift the large metal cover which spans across the back of the whole display.
  6. Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: passo 6, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: passo 6, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: passo 6, immagine 3 di 3
    • Carefully remove the two tape plugs on either side of the control board using a spudger.
  7. Apple Cinema Display M8149 LCD Screen Replacement: passo 7, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 7, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Pull the previously removed tape out from the metal box with your hand.
    • Peel back the white plastic cover located on the tape plug and unplug the tape plug on the right side of the unit using the spudger.
  8. Apple Cinema Display M8149 LCD Screen Replacement: passo 8, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 8, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement: passo 8, immagine 3 di 3
    • Unscrew the four screws (4.79x2.33mm) on the metal box using the Phillips #2 screwdriver.
    • Lift the metal cover off to reveal a circuit board.
    • Remove the two terminal screws (4.79x2.34mm) using the Phillips #2 screwdriver.
  9. Apple Cinema Display M8149 LCD Screen Replacement: passo 9, immagine 1 di 2 Apple Cinema Display M8149 LCD Screen Replacement: passo 9, immagine 2 di 2
    • Remove the terminal cover.
    • Remove the circuit board from the right side of the unit by gently lifting it out.
  10. Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: passo 10, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: passo 10, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: passo 10, immagine 3 di 3
    • Turn your attention to the left side of the cinema display.
    • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
    • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Remove the circuit board by gently lifting it from the display.
  11. Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: passo 11, immagine 1 di 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: passo 11, immagine 2 di 3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: passo 11, immagine 3 di 3
    • Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 10-41, Forte Spring 2011 Membro di Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Membri
12 Guide realizzate
2Commenti sulla guida
hello! where can i buy lcd screen for m8149?
jgill1971 - Replica
Does anyone know where to get an inexpensive LCD replacement. Mine went primarily magneta except for the outer edges after zapping the pram?! Totally bummed as I bought a DVI to ADC power source and now the monitor is useless in it’s current state. C’est la vie!
le_grand - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 43
Tutti i Tempi: 8,648
