Salta al contenuto principale
Anker 2.4G Wireless Mouse Scroll Wheel Replacement
Vincent Lee
Vincent Lee e 12 altri collaboratori
Ultimo aggiornamento il November 28, 2022
25 minuti
Moderato
Attrezzi Non Corretti
Introduzione
Vai al passo 1
If your Anker 2.4 G Wireless Mouse scroll wheel is not working properly it may need to be cleaned or replaced. Over time dust can build-up in the mouse causing issues with scrolling, this can be resolved with a simple clean. If there is hardware damage, the scroll wheel may need to be replaced.
This guide will show you how to disassemble your Anker 2.4 G Wireless Mouse to repair the scroll wheel with little to no experience required.
For help with desoldering, see: Come saldare e dissaldare componenti elettrici
Cosa ti serve
Strumenti
Mostra di più…
  1. Anker 2.4G Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: passo 1, immagine 1 di 1
    • Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
  2. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
  3. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: passo 3, immagine 1 di 2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
  4. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: passo 4, immagine 1 di 1
    • Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
    • Don't pull the wires too hard, as they might break.
  5. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: passo 5, immagine 1 di 2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: passo 5, immagine 2 di 2
    • Pull the scroll wheel put parallel to the board.
    • This may take some force to remove. Pull the scroll wheel out parallel to the board rather than perpendicular to it.
    • Replace/clean if needed.
    • If your mouse still does not work after this step, then continue to the next instruction.
  6. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: passo 6, immagine 1 di 1
    • Desolder the three pins, then solder in the replacement part.
Conclusione
Vincent Lee
Membro da: 01/23/14
361 Reputazione
3 Guide realizzate
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
16 Guide realizzate
1Commento della guida
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 47
Tutti i Tempi: 8,958
