Salta al contenuto principale
Amazon Fire TV Cube Speaker Replacement
Justice Davis
Justice Davis e 4 altri collaboratori
Ultimo aggiornamento il January 2, 2019
25 minuti
Moderato
Introduzione
Vai al passo 1
This guide will walk you through the step-by-step procedures to remove and replace the speaker in your Amazon Fire TV Cube. These steps are simple, however some require considerable force. To complete this replacement you will need a small screwdriver and opening tool.
Cosa ti serve
Strumenti
Mostra di più…
  1. Amazon Fire TV Cube Speaker Replacement, Speaker: passo 1, immagine 1 di 3 Amazon Fire TV Cube Speaker Replacement, Speaker: passo 1, immagine 2 di 3 Amazon Fire TV Cube Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Speaker Replacement: passo 2, immagine 1 di 3 Amazon Fire TV Cube Speaker Replacement: passo 2, immagine 2 di 3 Amazon Fire TV Cube Speaker Replacement: passo 2, immagine 3 di 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Speaker Replacement: passo 3, immagine 1 di 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Speaker Replacement: passo 4, immagine 1 di 2 Amazon Fire TV Cube Speaker Replacement: passo 4, immagine 2 di 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,458
