Salta al contenuto principale
Allow Code42 (Crashplan) Access to Backup Personal Files
Kevin Tully
Kevin Tully e un altro collaboratore
Ultimo aggiornamento il 18 mar 2021
1 - 5 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Apple recently introduced new privacy settings starting with macOS Mojave 10.14. These settings prevent Code42 (Crashplan) and other 3rd party applications from things like your Desktop, Contacts, Photos, Mail, Documents, Downloads, and other content and locations on your computer that contain personal data. These are often precisely the things that you are using your backup software to protect, so allowing Code42 Full Disk Access is essential to protecting your data.
These instructions apply to computers running macOS 10.14 (Mojave) through macOS 11 (Big Sur.)
  1. Allow Code42 (Crashplan) Access to Backup Personal Files, Open Apple System Preferences: passo 1, immagine 1 di 1
    • Click in the Apple logo in the top left hand corner of the screen, then select "System Preferences"
  2. Allow Code42 (Crashplan) Access to Backup Personal Files, Open Security and Privacy: passo 2, immagine 1 di 1
    • Select "Security and Privacy"
  3. Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: passo 3, immagine 1 di 3 Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: passo 3, immagine 2 di 3 Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: passo 3, immagine 3 di 3
    • If necessary, unlock the preference pane by clicking on the padlock in the lower left corner of the window, then enter your password. Once the padlock icon is in the open position, select the "Privacy" tab
    • Once in the Privacy tab, Scroll through the box on the left and select "Full Disk Access"
    • Check the box next to "Code42" in the "Full Disk Access" settings pane to allow Crashplan to backup your personal files.
    • The following message appears: "Code42" will not have full disk access until it is quit. Click Quit Now.
  4. Allow Code42 (Crashplan) Access to Backup Personal Files, Restart Your Mac: passo 4, immagine 1 di 1
    • Though not strictly necessary, it is good practice to restart your computer to allow the changes you've made to take effect. The next time Code42 launches, it should have the permission it needs to access your home folder and backup your Desktop, Documents, Mail, Contacts, Photos, and more.
    • For more information on this change, see Code42's documentation at: https://support.code42.com/CrashPlan/6/T...
Linea Traguardo
Kevin Tully
Membro da: 10/14/19
149 Reputazione
1 Guida realizzata
1Commento della guida
Great!! Thanks Kevin!
dahernandezs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,480
