Salta al contenuto principale
Akai MPK25 LCD Replacement
Will Saba
Will Saba e 8 altri collaboratori
Ultimo aggiornamento il 19 lug 2021
5 - 10 minuti
Moderato
Guida Studente in Evidenza
Introduzione
Vai al passo 1
Use this guide to replace a screen that is scratched, cracked, or broken.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Akai MPK25 LCD Replacement, Face Plate: passo 1, immagine 1 di 1
    • Remove all the selector knob covers by pulling them off.
    There’s NO need to remove all of the knobs in Steps 1 & 2…the faceplate lifts off with or without them attached.
    NY Prince - Replica
  2. Akai MPK25 LCD Replacement: passo 2, immagine 1 di 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
    Please, don’t use any pliers. Try to find a wrench in order to not damage the nuts nor scratch the panel. Anyway, many thanks for the explanation. Regards.
    Beto - Replica
  3. Akai MPK25 LCD Replacement: passo 3, immagine 1 di 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 LCD Replacement: passo 4, immagine 1 di 3 Akai MPK25 LCD Replacement: passo 4, immagine 2 di 3 Akai MPK25 LCD Replacement: passo 4, immagine 3 di 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 LCD Replacement: passo 5, immagine 1 di 3 Akai MPK25 LCD Replacement: passo 5, immagine 2 di 3 Akai MPK25 LCD Replacement: passo 5, immagine 3 di 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 LCD Replacement, LCD: passo 6, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the four 8.9 mm screws.
  7. Akai MPK25 LCD Replacement: passo 7, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the one 9.8mm screw holding down the ground wire.
  8. Akai MPK25 LCD Replacement: passo 8, immagine 1 di 2 Akai MPK25 LCD Replacement: passo 8, immagine 2 di 2
    • Using two plastic opening tools, slide the black locking mechanism on the ZIF connector towards you. This will remove the ribbon cable connecting the motherboard to the screen.
  9. Akai MPK25 LCD Replacement: passo 9, immagine 1 di 1
    • Lift the screen from either side, removing it from the board.
Conclusione
To reassemble the display, follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
Will Saba
Membro da: 01/11/13
412 Reputazione
2 Guide realizzate
Cal Poly, Team 20-6, Maness Winter 2013 Membro di Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Membri
6 Guide realizzate
1Commento della guida
Where can I find a new ribbon?
Wise Professor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,175
