Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
How to replace camera cable?
I broke the connector(camera cable), the one that is attached to the motherboard.
I ordered a new cable.
but now how do I connect it?
I need to remove only the plastic cover?
any manual or how to?
thank for answers.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The camera cable routes up through the display assembly to the camera board above the LCD. To completely remove it you have to pull off the display glass. It's a very delicate procedure, so be careful and work slowly.
Punteggio 2
3 Commenti:
well, but my is 2011, a you sure my case is the same?
da
by the way, my macbook still under in 1 year warranty, so in this case the can replace cable , or they reject to replace cable?
da
The unibody display assemblies have been nearly identical for 4 years. If your computer is under warranty, what were you doing to break the cable? Assuming there are no traces of you interfering with the laptop, they should honor your warranty.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
ressac sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 5,077
