Salta al contenuto principale
Lanciata in Nord America nel novembre 2006, la Wii è stata la prima console videogame domestica di Nintendo a supportare direttamente la connettività Internet, consentendo sia il gioco online che la distribuzione digitale di giochi e applicazioni multimediali tramite il Canale Wii Shop.
Drive Lens not moving.
I have the rvl-001 wii and the laser lens doesn't move along the track when I put the disc in. The only answer I found scouring the Internet is bad motor, or something might be jammed with dust or dry grease. I would like help in planning what I should do to identify the problem and how to fix it, because I don't wanna spend money to fix it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Could be many things.
It's possible that the laser died and is even unable to see the disc, hence it won't move.
It's also possible that the worm motor is broken causing the laser not to move.
And it could be the laser's clamp/bracket.
I always check the laser clamp/bracket first, if it's fine, I replace the laser. Still not working? Then I solder a new worm motor in.
You can check this guide: Sostituzione lente lettore DVD Nintendo Wii
Both are easy to replace (worm motor is a little soldering experience required).
I'm afraid you need to spend some money here. Glady, a laser and a worm motor is not that expensive. I would start with a new laser first, they are known to fail.
If you don't want to refurbish the drive, then just replace the whole drive and this should do the job as well. But this will be more expensive
Punteggio 1
Aggiungi la tua risposta
Adrian Proffer sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 24
Tutti i Tempi: 63
