Salta al contenuto principale
Questa unità raffredda o riscalda l'acqua che fa circolare nel pad di raffreddamento ChiliPad. Modello: CP-CUBE
NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @andrewlovell
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit Smontaggio del ChiliCube di ChiliTechnology guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
Immagine
(click on image)
Punteggio 2
2 Commenti:
Thanks for the info. I will let you know how i progress.
da
Fuse is good. So still looking.
da
Aggiungi la tua risposta
Andrew Lovell sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 7
Ultimi 30 giorni: 22
Tutti i Tempi: 92
