Salta al contenuto principale
Il terzo aggiornamento del controller wireless dell'Xbox è stato rilasciato a novembre del 2020, insieme all'Xbox Serie X ed S. Il controller è anche compatibile con i precedenti modelli di console Xbox One e i PC.
Potentiometer of joystick replacement problem
Hello,
I replaced the one potentiometer of joystick from a Xbox Series X controller but when trying it I was not able to calibrate it. Changed again and same thing. Does the potentiometer has to have an initial resistance value so I am able to calibrated? Maybe the resistance is very high/low to be able to
Questa è una buona domanda?
Punteggio 0
3 Commenti
Did you just change the potentiometer only or the whole joystick assembly? Did you try to cslibrate on a PC or an Xbox?
da
I changed only the potentiometer 2 times with no success. The the whole joystick worked. I calibrated it on a emulator in PC because I don't have an actual working Xbox Series X
da
Okay, glad that replacing the joystick worked. Should be OK now! Calibrating on the PC should do it! Have a nice day :)!
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi!
Whenever the potentiometer won't fix it, it's advised to replace the joystick assembly completely.
You can follow this guide for that: Sostituzione del joystick del controller wireless Xbox serie X/S
After this is done, you can try to calibrate them again.
Please let us know how it goes!
Punteggio 2
4 Commenti:
Hi,
Thank you very much. I discovered that I was using the same potentiometers I use for PS5 controller and the resistance value is different (PS5 2k3 ohm and Xbox 10k ohm) so that was the issue why I could not calibrate it
da
Ah that explains it!! It’s correct that they are different. Glad that you found out :)! Have a great day!
da
I replaced all my ps4 controller sticks with hall sensor ones. Never had a problem since.
da
Yes that works :)! But this is regarding a Xbox controller. I heard that sometimes it can interfere here with the magnets.
da
Aggiungi la tua risposta
sascha bauló martínez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 39
Tutti i Tempi: 148
