out of box failure
got 2 new units. neither one would charge & blue led charging light did not come on
Questa è una buona domanda?
@dougharder teh batteries are most likely discharged below their threshold and may no longer wake up. You will most likely have to replace those. Sostituzione batteria Black and Decker Pivot MAX or rebuild it for that you could use the SAMSUNG-30Q-18650-3000-FLAT cells.
After that re-evaluate and check the charging port and trace the wiring. Post some good pictues of what you find so we can see what you see Aggiungere immagini ad una domanda with your question.
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Guida
Difficoltà:
Facile
15 minutes
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 11
Tutti i Tempi: 104
