Salta al contenuto principale
La versione aggiornata del Nintendo 3DS da parte di Nintendo. Presenta schermi più grandi, una maggiore durata della batteria, una densità di pixel migliorata e un design più curato.
Weird System Power Issue
My 3DS is having a weird issue. When the 3DS's top screen's hinge is at about a 95-degree angle or less, the system works perfectly. However, if I push the screen farther back, the system fully turns off. I should point out that the system is not modded, meaning it isn't an issue after modding.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
That is weird. If you are OK with it, can you open it up and check the connections on the motherboard?
Punteggio 0
Hi!
I’m afraid it’s related to the top screen..
I would replace it and test if that worked.
Guide: Sostituzione schermo LCD superiore Nintendo 3DS XL
Note: it’s pretty difficult to perform this repair, so please check with the guide if you want to proceed or not.
Punteggio 0
3 Commenti:
Just be careful with the old screen, because if that's not the problem, I think you would want to return the new screen to iFixit for a refund.
da Condividi
Even if I replace the upper screen, why do I need a new speaker assembly?
da Condividi
What do you mean? I would only replace the topscreen for now.
da Condividi
Aggiungi la tua risposta
Bobus_Oxen sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 5
Ultimi 30 giorni: 17
Tutti i Tempi: 145
