Salta al contenuto principale
Il terzo aggiornamento del controller wireless dell'Xbox è stato rilasciato a novembre del 2020, insieme all'Xbox Serie X ed S. Il controller è anche compatibile con i precedenti modelli di console Xbox One e i PC.
New TMR Sticks Not Working
I am nee to soldering and know the basics. I replaced both joysticks with new TMR sticks with new Xbox joystick soldering tool. Replacement and soldering went well. But when I go to check controller with Xbox app, it connects but I can't move or use any part of controller. Any thoughts?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Hi!
Did you tried it here as well > https://hardwaretester.com/gamepad
What is working and what isn't?
da
Nothing works other than the controller turning on and connecting to xbox. I'd post a video if I could
da
Aggiungi un commento
1 Risposta
Hi!
Thanks for your comment!
Perhaps traces are damaged or the board went to hot.
Please check if everything is connected as it should and also for damaged traces.
I’m afraid your motherboard did die or isn’t connected properly.
Can you check this? Thanks!
Punteggio 0
2 Commenti:
I will have to check for this a little later, but that may be the case. I'm wondering if I may have had too much heat when desoldering the original analog sticks. Thank you
da
That is possible yes... In this case you most likely want to replace the motherboard, but this isn't cheap...
da
Aggiungi la tua risposta
kmuetz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 39
Tutti i Tempi: 234
