Salta al contenuto principale
Il Game Boy è uscito il 21 aprile 1989 in Giappone, seguito dal Nord America il 31 luglio 1989 e infine dall'Europa il 28 settembre 1990. È caratterizzato da una grande scocca grigia e dal numero di modello DMG-01.
Screen not displaying correctly
When I turn my gameboy on the screen has a big black box on it. If I put a game in it makes the Nintendo ding but nothing happens. I’ve attached pictures of the screen. I’m assuming it’s a gameboy issue and not a game issue or is it a both issue? Is it fixable !?
Immagine
Immagine
Questa è una buona domanda?
Punteggio 1
3 Commenti
@claired63511 your attached pictures do not show. Use this guide to add pictures. Aggiungere immagini ad una domanda.
"big black box on it" is usually a screen issue
da
I’ve added them now, sorry!
da
@claired63511 thank you for doing that.
da
Aggiungi un commento
1 Risposta
Risposta più utile
@claired63511 that indeed looks like a bad screen; those vertical lines are a petty good indicator that your screen has failed. The repair is not terribly complicated and there is a great guide for it Sostituzione Schermo Game Boy
Check online for replacement displays
Punteggio 1
3 Commenti:
Hi!
To add: under the screen you have a black piece of tape, remove this completely and then you can use the soldering iron with some solder on it on that spot. Just move your soldering iron from left to right and backwards, now you shall see that the lines are coming back again! Don’t hold your soldering iron too long on a spot, otherwise it will get burned. Do this many times, till you have all the lines back :)!
Sometimes, this method won’t work anymore or the lines are dissapearing again, if this is the case, you need to replace the screen..
Good luck with the repair!
da
@dan0 brother fixer you need to make a guide for that :-) That would be awesome!
da
@oldturkey03 good one! Will do that when I need to repair one again :)! I think next month I can create a guide about this!
da
Aggiungi la tua risposta
ClaireD sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 14
Ultimi 30 giorni: 28
Tutti i Tempi: 254
