Salta al contenuto principale
Il Super Nintendo Entertainment System (SNES), o semplicemente Super Nintendo, è una console videogame a 16 bit pubblicata da Nintendo nel 1990. Il Super Nintendo è stato uno dei best seller del suo tempo e ha ancora oggi una vasta fanbase.
What is causing my image problems?
I have 2 SNES consoles. I load Donkey Kong 2 one one and it looks great. I load it on my other and it looks funny. See images attached for what it should look like and what it does look like. I have a SNS-CPU-RGB-01. I'm assuming one of my chips needs replacement but I'm not sure which
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Michael!
First of all, did you tried the "working" AV cable on both of them? Could be related to the cables.
Most likely is that the PIN connector is dirty inside. Did you tried to clean it with isopropyl alcohol? Would try this first and see how that goes!
Otherwise you might want to replace it to test, could also be the GPU causing this issue...
First I would try cleaning and the known working AV cable.
Please let us know how it goes!
Punteggio 1
Aggiungi la tua risposta
Michael Bender sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 22
Tutti i Tempi: 134
