Salta al contenuto principale
Rilasciata in Giappone il 12 dicembre 2004, in Nord America il 24 marzo 2005 e in Europa il 1° settembre 2005.
Non-functioning wi-fi switch on PSP1000
Hello,
I think the switch broke around 15 years ago, but there's no pressure on the physical switch on the left side of the console. Looking for advise or if there is even parts that are available before I start unscrewing anything
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi MattR!
This one is soldered on the motherboard unfortunately.
If you have soldering experience, you can replace it!
The part can be found here: https://store.richspsxparts.com/newinwls...
If you don’t know how to solder, it’s recommend to learn this first.
You can replace the motherboard, but this will be more expensive!
Please let me know if you need any guide!
Punteggio 2
2 Commenti:
I have some soldering experience but mostly just some light plumbing and breadboarding in high school 10+ years ago. I think I’m up for the challenge though! A guide would absolutely be appreciated too!
da
Ah, then it will be a challenge, but it's fun to do!!
Guide: Sostituzione scheda madre PSP 1000
This guide is meant for taking the motherboard out. The part you need to replace, can be seen in the link where you can buy the part! If you need something more detailed, let me know! Good luck with the repair!!
da
Aggiungi la tua risposta
MattR sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 72
Tutti i Tempi: 740
