How to fix adapter
How to fix adapter
Questa è una buona domanda?
Hi
Most laptop adaptors are sealed switch-mode power supplies. If it has a damaged connector or cable you could fix it if you can solder. But you will find cheap Chinese knock off adapters on eBay for less than the price of the parts and used genuine adapters at a decent price. You probably aren’t fixing it, but you should ensure the power supply is the issue by checking the voltage across its connector if it does not have a physical problem.
Best regards,
Robin
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 16
Tutti i Tempi: 252
Hi @sabahemmanuel
More information is needed to help you.
What kind of adapter i.e. power adapter, cable adapter etc?
What is the problem with the adapter?
Post an image of the adapter in your question showing what the problem is if it is a physical problem i.e. broken. Here's how on ifixit Aggiungere immagini ad una domanda
da jayeff
Power adapter for laptop. The one with the big pin
da Sabah Emmanuel
I will send the image to you but is not with me now
da Sabah Emmanuel
