Salta al contenuto principale
This range of HP colour printers are built around the same print engine. They were manufactured between 2015 and 2019. These printers use 508A and 508X toner cartridges.
How can I replace a broken display screen?
The printer display screen is broken - I cannot read what is on the display. How can I replace this so it works again?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@renep75598 you did not tell us the exact model for your printer. There are difference between the M552,M553 and M577. The display on those is called the "Control Panel". Use the Remove Control Panel M553 And M552
If your model is different, let us know so we can at least get you the right guide :-)
Punteggio 1
Aggiungi la tua risposta
Rene P. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 33
