How to fix it... it is not turning on...
Immagine
Immagine
Immagine
Immagine
Automatic Hair Curler Auto Hair Curling Iron Ceramic
Rotating Air Curler Air Spin Wand Styler Curl
Machine Magic Hair Curler
Hello, how to fix this amazing automatic hair curler... it was amazing, some how it is not turning on... ...I tried to open but is quite impossible to open to fix it...
Any help please... if you wanna see the image, get the name and search on AliExpress... please help🙏🏻
Update (03/29/25)
Here are some more pictures
Immagine
Immagine
I unscrew the 3 screws and tried to open but it did not open, pull the bottom where the cabe is and it did not came out... tried to twist head from body and nothing worked...😭😭😭
Thanks for any help!!!
Questa è una buona domanda?
Punteggio 0
4 Commenti:
Hi @angel75790,
What is the make and model number of the hair curler, you didn't state its name in your question?
da Condividi
Hey @jayeff thanks for the reply!
So, on the box only says Automatic Curling Iron NO WT-123 that's why I said to look for the description( Automatic Hair Curler Auto Hair Curling Iron Ceramic) on Aliexpress, here I can't send pictures and the product didn't came with much info...
da Condividi
@angel75790 yes, you can. You just have to add images to your Question via the edit command. Here is the guide for that Aggiungere immagini ad una domanda It is always advised that you take pictures of your device and not of some stock device
It'll make it a lot easier for those that are trying to help you.
da Condividi
Awww really? Thanks for the tip @oldturkey03... I will try to do that...
Thanks a lot!
da Condividi
Aggiungi un commento
