How to repair my display glass only wether display
The glass of my phone's display is broken or something is damaged, I need to get it fixed
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
@originaldi62402 I do not recommend that you try a glass-only repair for a display issue. I strongly recommend that you replace the complete assembly. While a glass-only repair is slightly cheaper, it is also more complicated and requires some more expensive tools. I recommend a complete display assembly replacement. It is a bit more costly but your success rate is almost guaranteed. It is also quicker then a Glass-only.
Since iFixit does not yet have a specific guide for that, use something like this video to replace the display assembly. Replacement displays for your phone are readily available at many online places.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 5
