Salta al contenuto principale
The XV40 Camry was introduced at the 2006 North American International Auto Show alongside a hybrid version and went on sale in March 2006 for the 2007 model year.
Why won’t my car go in fourth gear
My transmission is slipping and it won’t go in fourth gear it revs high it’s automatic 2007 Toyota Camry LE four-cylinder I thought it might be a sensor or something making a slip I check the fluid transmission fluid good
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If your transmission has gotten to the point of slipping it may be time for a rebuild or transmission swap!
On the off chance that it COULD be just low on fluid, most vehicles recommend checking the transmission fluid with the vehicle running at operating temp.and in park. This way the transmission pump is engaged and the level on the stick would represent the actual amount of fluid that is flowing thru the system not just the static amount that is gathered in the pan!
Punteggio 0
Aggiungi la tua risposta
John Gilbreath sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 14
