Salta al contenuto principale
Repair and disassembly information for Samsung's flagship S20 FE Android smartphone, released in October of 2020. Identified by model numbers SM-G780F or SM-G780F/DSM
20 Domande Visualizza tutte
Not charging even after replacing battery, daughter board and flex
As stated, phone wasn't charging so I replaced the daughterboard and battery. Still wasn't charging so I also replaced the flex cable, and it is still not charging. Anything else I can try?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
check the fpc connector for the flex on the main board, samsung fpcs are known to easily break, check the left side of it
Punteggio 2
1 Commento:
It wasn't broken, but when I pressed on the connection, it began charging. I pressed a little extra hard along the connection and it's now charging, so it seems like the it may be a little "loose" or finicky, but it's working now. Thanks!
da
Aggiungi la tua risposta
Terranq sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 32
