Salta al contenuto principale
My CPU Start But In Monitor Display No Signal
cpu working but in monitor display no signal
Questa è una buona domanda?
Punteggio 4
5 Commenti
My power supply is working but no sign of the computer is going to turn on
da
Hi @mahlatsedoeboy
Please confirm the make and model number of the motherboard?
da
mpg x570 - moba
da
@iantorchteeh
check if any EZ debug LEDs are turned on, on the motherboard.
Go to p.24 of the user manual to see where they're located on the board
da
thanks..new problem now is the USB port not active.
da
Aggiungi un commento
3 Risposte
Risposta più utile
Possibly the RAM
Punteggio 1
first check your blue cable adapter connect to your graphic port, if still it doesn't work , then to my suggestion check your RAM , maybe there is dust inside the ram port or one of the ram is not working
Punteggio 0
1 Commento:
I have checked the RAM port but found nothing.
da
@iantorchteeh
If the PC is turning on with a display and Windows is the OS check that the USB Root Hub Power management setting "Allow the computer to turn off this device to save power" is unchecked.
Go to Device Manager¹ → Universal Serial Bus controllers → right click on a USB Root Hub entry in the list → Properties → Power Management → Uncheck the setting → OK.
Do this for all the Root Hub entries listed under the category.
Once completed, close any open windows and then restart the PC in the normal manner and then check if the USB port works OK.
¹ To get to Device Manager in Win10/Win11, press the Win key + x key (both keys together) and click on the Device Manager link in the menu box
Punteggio 0
Aggiungi la tua risposta
Unknown User sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 68
Tutti i Tempi: 1,082
