Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel giugno 2017, questo MacBook Pro ha processori Kaby Lake fino a Core i7 da 3,5 GHz con Turbo Boost fino a 4.0 GHz.
How to change the keycaps
I need to replace the keycaps on a old touch bar MacBook pro is there anything that I should know as I'm used to PC laptops and have never worked on a MacBook is there anything that I should know?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
These key caps are extremely easy to break. So going in prepared is key. :)
If you haven't taken a look at the internals of the key switch here's a picture that will probably help more than anything.
This image is a bit newer model, but the mechanism is largely the same. The key to damage free removal is to use something slim (like iFixit's Jimmy or an iSesamo) to get under the top edge of the key cap. That's the side with the clips, and the bottom edge has a little hinge in each corner that can take the posts on the key switch out too if you're not gentle.
There's also a Guide if you want a more step by step.
Immagine Springy steel blade features a smart tip design and a handle with a great no-slip grip. Effortlessly pops open iPod, iPad, iPhone and many other tablets, smartphones, and devices.
Prodotto
iSesamo Opening Tool
$9.99
Immagine Handy tool for opening electronics.
Prodotto
Jimmy
$7.95
Punteggio 2
Here is a good video that shows you how to replace the keys :)
Punteggio 1
Aggiungi la tua risposta
frey_code sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 91
