Salta al contenuto principale
HP Envy x360 is a line of laptops made by the company since 2014. They feature a touchscreen and a fully rotating display.
Screen and Hinge Repair
Hello, I have a HP Envy x360 Convertible 13-ay0xxx laptop and my right hinge broke and cracked my laptop’s screen too while closing/opening the laptop.
Product Number: 9VT59UA#ABL
I need help to find the correct parts to buy (shipping to Canada) and I am unsure if simply buying a screen replacement will do the job to adjust hinge correctly.
Will it be possible to have a repair guide to replace broken hinge/screen please?
I was also looking to possibly replace the battery for a new one.
Let me know if you need more information.
Thank you in advance for your time and help!
P.S. Here is a video showcasing the issue on my laptop: https://www.dropbox.com/scl/fi/5epcs2fx2...
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I have reviewed your video.
You should know: your hinge is not broken, your LCD back panel is what broke. If you replace the hinges, you're not going to solve the problem and instantly this will happen again.
I do not know about vendors in and/or shipping to Canada, so I can't help you there. But you likely need the following part numbers:
LCD Cover: L94498-001
LCD Screen: L23211-001
These are the part numbers as seen from my supplier. Please note that I HIGHLY RECOMMEND you take apart your screen and find the part numbers (should be the same format as my examples, but possibly different numbers) on your exact computer before ordering replacements, as it is possible the Canada market has different parts than the US market.
Hope this helps!
Punteggio 2
2 Commenti:
Thank you for your help!
da
Yo sir I've got a same laptop and for me the top panel came off at the right hinge. Here's the link of photos https://www.dropbox.com/scl/fi/nc1glaksp...
https://www.dropbox.com/scl/fi/uvbs4kq8b...
da
Parti e strumenti correlati
Aggiungi la tua risposta
Leo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 185
Tutti i Tempi: 975
