Salta al contenuto principale
The Meta Quest 3 mixed reality headset was released on October 10th, 2023 and is the direct successor to the Meta Quest 2 and in many ways the spiritual successor to the Meta Quest Pro.
What material is the heatsink
I want to see if liquid metal is possible for the quest 3 since i want to overclock it
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Howdy there dan.
The heatsink is aluminum, so it is not advised that you use liquid metal since it will react with the liquid metal.
Best of luck to you!
Punteggio 3
3 Commenti:
Thanks alot ill stick with thermal sheets and yeester paste or arctic mx4
da
@dandan0 If you're looking for reccomendations iFixit's thermal paste is pretty good, and is relitivly inexpensive.
da
I have some already its just those have better thermal conductivity
da
Parti e strumenti correlati
Aggiungi la tua risposta
0DanDan0 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 119
