Salta al contenuto principale
Lanciato a maggio 2020, il MacBook Pro da 13" ha dei processori quad-core Intel di ottava generazione Core i5 e i7, e grafica integrata Intel Iris Plus 645. (Modello A2289/EMC3456 con due porte Thunderbolt 3)
How do I replace the camera?
My camera is not working, can someone explain how to replace it please. The green light comes on but no image
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Start by resetting the NVRAM and SMC. If that doesn't help, then you know you have a hardware issue with the display. Replacing the camera itself on these models is not easily done. You would need to fully disassemble the display assembly and do some very delicate microsoldering. The more feasible approach is to replace the display assembly, but the displays on these can be pretty expensive. Here's a link to a display. Good luck!
Punteggio 0
Parti e strumenti popolari
Acquista tutti
Is this the original display that came with the system?
Punteggio 0
You might be better off just using an external web cam when necessary as the 'repair' to fix the possibly damaged camera is a nightmare of a job when it comes to removing the screen glass and all to get to the camera part...... Have you checked inside that all the cables are in place..... Gruppo schermo MacBook Pro 13" due porte Thunderbolt 2020
Punteggio 0
Aggiungi la tua risposta
Ronald León sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 57
