Salta al contenuto principale
Repair guides and support for the Lenovo Ideapad 310-15IKB, a midrange consumer laptop released in 2016.
Backlight not working even after screen replacement.
Hello,
I spilled coffee on my laptop. I got the laptop back running normally after unplugging the dock connector and it worked fine for a long time. But the coffee also got into the screen and it was driving me crazy. I decided to try to fix the screen by taking it apart and wiping the coffee away. When I plugged the screen back, the backlight wasn't working. I ordered a new screen and I got the same issue. I think it might be an issue with the motherboard. The old display could short the circuit. Where are the backlight fuses located?
Thanks for help, Jacob
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
To locate the backlight fuses on your Lenovo IdeaPad 310-15IKB inspect the motherboard, particularly near the LCD connector, for small surface-mounted fuses. Use a multimeter to test these fuses for continuity.
Punteggio 0
2 Commenti:
ye i cant click links, my mom disabled it
da
Aggiungi la tua risposta
Jakub Chmelař sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 93
