Salta al contenuto principale
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
How to remove and replace the heater fan
How do I replace the heater fan motor
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
  • Disconnect Battery: Unhook the negative battery cable.
  • Remove Glove Box: Unscrew and take out the glove box.
  • Access Blower Motor: Remove any covers or panels blocking the motor.
  • Replace Motor: Unplug the old motor, remove it, and install the new one.
  • Reassemble: Put everything back together and reconnect the battery.
  • Test: Turn on the vehicle to make sure the new motor works.
Punteggio 0
1 Commento:
It was my fault that it was wrong. I should have told you that the truck is a 4 door model , 4 wheel drive, V8 motor. It is different than the two door truck.
da
Parti e strumenti correlati
Aggiungi la tua risposta
Ronald Brake Trotter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 56
