Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
Cable from logic board to hard drive
I can not connect the cable from the logic board to the hard drive back down secure the cable to the logic board. It is a " new " board I got from Ifixit. I get the cable in place, push the brown connector down, but it will not stay down. I tried to keep it down with Kapton tape but that does not work. Am doing something wrong ? The cable just lies atop the the the board and under the brown connector ? Any tips ??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@mike11595 all you should have to do is to open the black locking hasp (goes to a vertical position), then insert the HDD cable in between the brown connector and then lock the hasp, by pushing it back into a horizontal position. Make sure you have the cable right side up. This is really not a terribly complicated task. Sounds like something is up. Make sure that you insert the cable properly. It should not be laying on the board at all but be inside the brown ZIF connector.
Punteggio 1
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 26
