Salta al contenuto principale
The XV50 Camry was introduced on 23 August 2011, and began U.S. sales in September 2011. The interior received a major restyling, while the exterior received all-new sheet metal and more angular styling.
15 Domande Visualizza tutte
Why is my engine burning a lot of oil
why is my engine burning a lot of oil, I keep running dry on oil every few thousand miles.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@delayahu could be many things. Pull your spark plugs and see what those look like. It is possible that your engine has bad piston rings, bad pistons and cylinder walls, as well as damaged/burned valves. Do a compression test and a leak-down test. That will give you some more information about the general condition of your engine. Let us know what you find out.
Punteggio 2
Aggiungi la tua risposta
Delayahu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 29
