Salta al contenuto principale
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
Why Engine sound high in neutral also
Hi
My corolla car engine sound high while giving acceleration or in netual also
Questa è una buona domanda?
Punteggio 0
1 Commento:
You mean the idle speed is very high, when it should be around 720 RPM ?
da
Aggiungi un commento
1 Risposta
Stuck accelerator or linkage at idle. Also could be lean mixture.
Slipping transmission when accelerating.
You need to make more observations to get a good answer.
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Minhaj bc sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 45
