Keyboard keys pressed automatically
Many keys are functioning automatically so currently using powertool application to disable the key, need a better solution
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
It sounds like you might be experiencing a hardware issue with your keyboard. Before resorting to software solutions like the Powertool application, try cleaning your keyboard thoroughly to remove any debris or dust that might be causing the keys to stick. If the problem persists, you may need to consider replacing the keyboard altogether.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 33
