Salta al contenuto principale
The Dyson DC58 is manufactured by Dyson. It is an easy to handle, handheld vacuum powered by a V6 motor that provides powerful suction for up to 20 minutes.
How do I stop pulsating?
How do I stop my DC 58 from pulsating?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@barbarahayes the pulsating is most commonly caused by a clogged filter. You can either wash it out or replace it. I've tried the washing and failed. I ended up replacing mine which stopped the pulsating competently. Check the first 2 min of this video
Depending on how much debris is already inside our Dyson, you may also have to look into a total disassembly to clean it out. Use these guides Dyson DC58 to work on it.
Try the filter first.
Punteggio 1
Parti e strumenti popolari
Aggiungi la tua risposta
Barbara Hayes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 52
