Salta al contenuto principale
The Razer Blade (2018) is a 15.6-inch gaming laptop released in May 2018.
How do I know if the battery from iFixIt is compatible?
I need to replace the battery on my Razer Blade 15 Mercury, I purchased the laptop back in 2018 and is a US model, delivered to the UK.
On the back it has the model number: RZ09-02385.
I'm looking at purchasing the one from the store: Razer Blade 15" (2018/2019) Laptop Battery
The page does not say model numbers for the 2018 model. Is there a way I can tell it will be compatible?
Immagine Replace a 4221 mAh battery compatible with your Razer Blade Laptop. 65 Watt Hours (Wh). 15.4 Volts (V). Part #RC30-0270.
Prodotto
$99.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I managed to open up and view the battery model number, for anyone that interested; the battery required is
Model: RC30-0248
Rated Capaticty: 5209mAh / 80Wh
Rated Voltage: 15.4V
This look like it will match, although the page says 2020 advance model, I purchase my Razer Blade in 2018.
Razer Blade 15" Advanced Model Laptop Battery
Immagine Replace a 5209 mAh battery compatible with your Razer Blade 15" 2020 Advanced model Laptop. 80.2 Watt Hours (Wh). 15.4 Volts (V). Part #RC30-0248.
Prodotto
$92.99
Punteggio 0
Review the label info on your battery and the one being offered do they match up? Model number, voltage and mAh?
Punteggio 0
2 Commenti:
Thanks, I was hoping to buy both the battery and the kit to open up at the same time but looks like I will need to buy the kit first to open up the laptop again. My T5 driver is more like a circle now.
da
Thanks, I managed to access the battery, it is model RC30-0248, so the battery in my original post is not the right one.
da
Aggiungi la tua risposta
DigiKris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 127
