Salta al contenuto principale
Repair information for Sony Bravia 32" LCD TV. Released in 2008. Model number: KLV-32T400A.
Tv will be automatically off
TV it will be automatically off
Questa è una buona domanda?
Punteggio 0
1 Commento:
@santoshull69133 what is the exact model number for your TV? What have you checked? What have you tried? Explain to us exactly what happens. You chin your TV on and it turns right back off? Does the power LED blink? Any specific code?
da
Aggiungi un commento
1 Risposta
Firstly, check if you have unknowingly set an automatic shutoff timer in the TV settings. If that's not the case usually this symptom is indicative of faulty capacitors on the mainboard or power board of the TV at least with Samsung TV's. I suspect similar symptoms could occur on Sony TV's as well, If you're comfortable with doing so, you can open up the TV and check for any bulging capacitors on both the mainboard and the power supply board.
Punteggio 0
Parti e strumenti correlati
Aggiungi la tua risposta
Santosh Ullagaddi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 42
