Salta al contenuto principale
15-inch HP convertible with model number 2PS98EA.
How to replace broken hinge?
my hinge is broken on one side. I've got it removed because nobody wanted to touch my laptop as it's touchscreen.
Questa è una buona domanda?
Punteggio 0
1 Commento
How do I repair winges on my Hp 15 bs144rm
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I have done this repair and as someone who has done repairs on laptops for a very long time. This was my absolute least favorite repair ever. I ended up having to replace the entire screen as well as both of the hinges. This is a well known problem with this laptop which I suspect why no one wants to touch it. Even the slightest flex of the screen which must be taken out to do this repair will crack the outer layer of glass and you will end up having to replace it.
I would caution anyone attempting to repair this issue on the machine and would likely turn down the next one I see for repair as well. It is simply and honestly put not something that can be done easily and even when completed. I can see this happening again because of the poor design of the hinge system overall.
I'm not saying you cannot do it, I am saying go ahead and order an extra screen from the start. you are likely gonna need it.
If you do replace it moving forward after replacement use both hands always to open the screen equal distance apart as a single hand open will put more force on one of the hinges and this is how it fails.
I sourced the replacement LCD from here. https://www.ebay.com/str/ftdlcd both the screens worked fine and came pretty fast.
I sourced replacement hinges from here. https://www.ebay.com/str/honthstore they were identical to the originals.
If you have any further questions about this repair you can post back and I will do my best to answer your questions or even help you through a repair.
Cheers
Monte
Punteggio 3
1 Commento:
can confirm everything you said!! Dealing with one now
da
Parti e strumenti popolari
Aggiungi la tua risposta
Sneha Yadav sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 91
Tutti i Tempi: 961
