Salta al contenuto principale
Released October 2013, model number: ZHN.
Is there a way to upgrade the SSD?
Hi!
I am looking to upgrade the SSD from 16GB to at least 32GB for my Chromebook that I use Ubuntu on. I need help looking for SSD's that would fit into this Chromebook, as this Chromebook uses a small SSD that I can't find in a bigger size.
Can you guide me in the right direction to find a bigger SSD that is the same size but holds more in storage?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@jri_creator it uses a SATA 3 M.2 (NGFF) SSD and it is 42mm in length, better known as 2242. M.2 SATA 2242 ssd are readily available at many online stores with way more than 32GB for not a lot of money.
Punteggio 1
Aggiungi la tua risposta
Jri-creator sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 121
