Salta al contenuto principale
Informazioni su riparazione e smontaggio per lo smartphone Google Pixel 6, lanciato nell'ottobre 2021. Identificato dai numeri di modello GB7N6 e G9S9B16.
Screen unresponsive after light rain
My Google Pixel 6 was exposed to light rain. After I dried it the screen became erratic. It slowly got worse and although looks 100% is now no longer responding to any touch.
- I have rebooted
- Removed the screen
- Tried safe mode.
I don't mind buying and fitting a new screen, but I need to know if there could be anything else that would potentially stop a screen responding before I purchase and fit. Or would a new screen 100% fix the problem?
Thanks!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @davejohnso16365
You said that you removed the screen. Whilst it was removed, did you check the status of the LDI in the phone or look for any other signs of water ingress or corrosion, as you never mentioned it?
If the LDI is indicating the water has entered or if there's evidence of corrosion then this may have to be looked at before replacing the display.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again or perhaps the screen will have to be replaced anyway. At least you know that there's not much else wrong that could be causing the problem.
Here is the ifixit Google Pixel 6 repair guide that may help.
Punteggio 3
1 Commento:
Really appreciate that. The LDI is white so all good there. I may just order a screen, swap it out and if it's the same I can send it back again as long as I am careful. I guess I don't have to swap over the thumbprint sensor and any other bits to actually test to see if the screen is working ok.
da
Aggiungi la tua risposta
Dave Johnson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 58
Tutti i Tempi: 3,771
