Salta al contenuto principale
Modello A1059 o A1099 / disco rigido da 20, 40 o 60 GB / ghiera clic sensibile al tocco
How to bypass battery
Hello All.
first timer here, new to the fourm. I have an ipod 4th gen that i'm trying to fix. I would like to bypass the battery to do some troubleshooting. anyone have any tips on how to do this? I was just thinking on pluging in 3.3v from a breadboard powersupply to the battery input.
Thanks in advance to any input and tips.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
I'm not very familiar with the 4th gen but from what I've seen it seems the battery is a 3 pin? Black is ground red is positive and a third white or yellow wire is presumably some type of thermistor. I would try applying gnd to black and 3.7v to red on the motherboard, check if it powers on, if it doesn't then it expects a signal on the thermistor pin coming from the battery. On most phones you can get away with pulling the thermistor pin on the motherboard to GND essentially 'emulating' a thermistor, I suspect it would work similarly on the iPod
Punteggio 1
Aggiungi la tua risposta
ksharp117 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 7
Tutti i Tempi: 284
