My mobile screen problem
my mobile screen problem
Update (01/24/24)
my display line shown new update
Questa è una buona domanda?
@realme7pro sounds like you are saying that your phone display shows lines. That can be caused by either a bad display or by a bad connector and circuit board. I suggest that you start with a new display.
Since ifixit does not yet have a guide for this, use the one from here It is in Spanish but your browser should have no issues translating it. Replacement screens are available at many online stores. Do a search for it within you region.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Can't touch the screen. How to Fix It
@harithmage what make and exact model is your phone?
Display change
@vedansh the same way as in the original answer.
My phone died 😞
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,890
My mobile display is not working
da Realme
@realme17135 have you done anything as suggested in the Answer?
da oldturkey03
Phone screen broken and not working properly
da Shashi Kant
@shashikant14440 not enough information to be certain but if you have issues similar as the original question, do the same as suggested in the original answer. Replace the display.
da oldturkey03
Phone work nhi Kar rha Hai
da Pinkusoni
Mostra altri 6 commenti
