Salta al contenuto principale
How to disassemble the screen to replace the LED matrix cable?
How to disassemble the screen to replace the LED matrix cable? (Gigabyte Aero 16 RP86 XE4)
Update (01/11/24)
I need to disassemble the screen to replace or restore the cable
Questa è una buona domanda?
Punteggio 1
4 Commenti
Hello, You mean the led strip for display backlight?
da
Iam not 100% sure but this model should have oled display, thats mean no backlight LED is there.
da
Hi! Did you manage to fix your issue? Did you dismantle the whole thing, or could you find a replacement cable?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The plastic frame should be glued, try to heat the display housing little bit and remove the frame... when is oled display you can use also alcohol for make easier remove the glue
Update (01/11/24)
First remove the hinge part
Punteggio 2
Parti e strumenti correlati
Aggiungi la tua risposta
Sergei Diev sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 34
Tutti i Tempi: 500
