Salta al contenuto principale
Why no display on screen
Laptop blinks 2orange and 7 white colors repeatedly
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
What I would do in this situation is take off the back, disconnect the battery and see if it boots up, If that doesn't work then I would take out the memory and replace it with known working memory and see if it works. I have seen this previously and sometimes the Ram just needs to be reseated or replaced in most cases. If it turns on but still doesn't display. Connect it to the external monitor or tv. If it displays with no issues then your screen is bad. If it doesn't display then you possibly could have a board issue.
Punteggio 0
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Sisco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 88
