Salta al contenuto principale
Second generation of Toyota Yaris.
How to fix p0900
How to fix toyota yaris Automat girbox p0900
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Haile,
That particular code happens on several Toyota models including the Auris, Corolla, Verso-S and Yaris. It's indicating a problem with the Clutch Actuator Circuit, which is a device mounted on the transmission. There is a TSB, or Technical Service Bulletin regarding this problem that indicates that it may be covered under warranty if your car qualifies. Here's a link to the TSB you'll want to take a look at.
CP-0022T-0411-EN.pdf
You might want to print it out and take it to your nearest Toyota dealer and see if they will fix the problem under warranty.
Otherwise, since the TSB gives you step by step instructions for doing the repair, you could certainly follow them yourself and fix it without going to the dealer, although that would be my first choice if they are willing to do it at no cost.
Punteggio 2
Parti e strumenti correlati
Aggiungi la tua risposta
Haile Medhane sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 45
Tutti i Tempi: 793
