Salta al contenuto principale
Would like to change my motherboard
My msi stealth gs75 9sg graphics card died. In device manager it has a code 43 and a nvnvlddmkm blue screen error code along with a SYSTEM_THREAD_EXCEPTION_NOT_HANDLED blue screen error. I did everything possible including the DDU.
I want to know if I can swap my motherboard with the exact same specs and motherboard set up. On ebay there are some exact motherboard models. I wanted to know if it is safe and okay to replace my motherboard?
Laptop specs
Model: Msi Stealth gs75 9sg
Gpu: Rtx 2080 max q
Cpu: i7 9750h
Ram: 32gb ddr4
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@kentracerd38110 yes, it is absolutely okay to switch like for like. If you found a motherboard with the same specs and numbers as your, it is okay to switch it.
Punteggio 0
Aggiungi la tua risposta
KenTracer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 144
