Salta al contenuto principale
Supporto per la calcolatrice Texas Instruments TI-84 Plus.
Why is my screen frozen
When I turn on my calculator I none of the buttons I press work, the cursor is blinking on the screen but I can’t even turn the calculator off. I tried removing the batteries and charging it and that didn’t work.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @leighacox
Try the following and check if it resolves the problem.
Remove the batteries and the back up battery from the calculator and then press and hold the ON button for a full 20 seconds and then release it.
Note: Remember the way that the back up battery was installed (+ve on top as seen on the battery itself) so that you reinsert it the correct way.
Reverse the procedure to reassemble the calculator and check if it turns on and works OK.
Here's the ifixit Smontaggio TI-84 Plus guide that may help. You don't have to go past Step.5
Punteggio 0
Aggiungi la tua risposta
Leigha Cox sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 18
Ultimi 30 giorni: 97
Tutti i Tempi: 1,711
