Salta al contenuto principale
Repair guides for displays (or monitors) for computers or other devices with video output.
What is causing this on my screen?
I have an MSI Stealth Laptop with the 240Hz screen and just recently these dark areas showed up on the bottom my my screen. Looks like some of the LED back/edge lighting has stopped working. Anyone else have this issue or know for sure what it is?
The dark areas are hard to see in the picture. But in person you cant miss them.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
It looks like the backlight in your screen is failing. An LCD replacement should fix it.
Punteggio 2
Parti & Attrezzi Popolari
Easiest fix: Replace the whole LCD panel for it.
If you want to try and fit a new backlight to the panel, You could try before you buy a new one.
But if you want neither, It won't hurt anything, Looks like only one row failed.
It won't break the whole laptop.
Punteggio 1
Aggiungi la tua risposta
Patrick Auer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 33
