Salta al contenuto principale
How to remove Red X from Sound Icon
  1. My pc sound is not working. It says no speakers or headphones are plugged in. It puts x mark on volume button. I have tried YouTube videos none of them helped me. I saw your about your website on tiktok. Thanks in advance for your cooperation.
Questa è una buona domanda?
Punteggio 0
3 Commenti
Have you tried clicking the sound button, and opening up sound mixer?
da
Yeah. Didn't work
da
@hajijawaro are you using Windows on this computer? which version? Have you checked under device manager what it tells you about your Sounds output etc? Has it ever worked for you? Did it have Sound before? Anything happened to it?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Looks to me like your audio is not being found. You could always try the Windows troubleshooter first. Right-click on the Speaker/Headphone icon . Then select troubleshoot sound problems. That should start the troubleshooting process. LEt us know what it finds.
Depending on your version Windows, you may also want to go and check to see if your audio is enabled/disabled in your device manager.
If all of that looks okay, I would update the audio driver. Check on here for that.
Remember, Toshiba is a crazy company, like Apple only worse. They are really, really paranoid and secretive. Do not expect any help from that company.
Punteggio 0
2 Commenti:
I'm afraid. Still my problem is not resolved
da
@hajijawaro you need to let us know what you have tried.
da
Aggiungi la tua risposta
melal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 89
