Change the radiator water
كيف يمكنني تصفية ماء الرديتر واعادة التعبئة
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
@nawaf55330 from the service manual:
DRAIN ENGINE COOLANT
CAUTION: To avoid the danger of being burned, do not remove the radiator cap while the engine and radiator are still hot, as fluid and steam can be blown out under pressure.
2. FILL ENGINE COOLANT
NOTICE:
Do not use an alcohol type coolant or plain water alone.
The coolant should be mixed with plain water (preferably demineralized water or distilled water)
Capacity of the coolant for Manual Transmission is 4.4 US qts. (4.2L) and 4.3 US quarts (4L) for the Automatic Transmission vehicles
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 40
Tutti i Tempi: 500
