Salta al contenuto principale
Il Razer Blade Stealth è un portatile da gaming con schermo panoramico da 13,3 pollici. Il portatile è dotato di 16 GB di RAM e CPU Intel Core i7. È disponibile nei colori Space Grey e Mercury White.
add or replace RAM
i would like to change out my ram. or add another memory module if possible. what ram does the computer use?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
First, I would want to know for sure which model you have (there are a lot of devices at iFixit, but there are so many Windows laptops it would be hard to have device pages for all of them).
But assuming you have categorized this correctly (and based on my experience with other Razer laptops), the RAM is not upgradeable. It is soldered directly to the motherboard. I would wager these are the RAM chips on the board. Occasionally a slot shows up on the back of laptop boards, but that is more often for a second SSD than RAM unless it's a beefy enough system that it can accommodate 4 RAM sticks.
Immagine
Punteggio 2
Aggiungi la tua risposta
JJ Amaro sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 24
Tutti i Tempi: 681
